Eric12345
Aug 15, 2013Aspirant
Could not connect to volume
Hi, I have tried a few times to connect FileZilla to my ReadyNAS Duo v2 volume but every time I tried it I could only seen the directory "media". But half a year ago when I tried that I've seen the w...
Aug 15, 2013Guru - Experienced User
If you turned it on for home shares, and every public share, then you can access the entire disk. The one restriction is that you'd only see the home share for your user login (which is always true for home shares).
Eric12345 wrote: Ok, I turned FTP for each share on and I can access to each but I would access to the whole disk. Is this possible?
Can you clarify what you are wanting to do?
