SGT_Oldy
Nov 18, 2019Aspirant
Could not delete share due to snapshot deletion failure, Code 1004030000 OS6
I have a ReadyNAS 316 OS 6.10.2 with 3x2TiB + 3x4TiB disks so currently at 12TiB. Seem to have a problem with one of my share folders. I am unable to delete a share due to a snapshot deletion error a...
- Nov 19, 2019
Clearly the file system for the data volume has become corrupted somehow. The most conservative approach is to do a factory default, rebuild the NAS, and restore the data from backup.
If you purchased the NAS (new) between 1 June 2014 and 31 May 2016, then you have lifetime chat support at my.netgear.com. You could try using that if you have it.
SSH is another possibility - using it to manually delete the snapshots and share. You'd log in as root, using the NAS admin password.
You can list the btrfs subvolumes (e.g., shares and snapshots) with btrfs subvolume list /data
Then you can manually delete the ones you want to get rid of with btrfs subvolume delete <path>
You need to use the full name in the path (e.g., it needs to start with /data/OldChive ). When deleting snapshots you need to delete each one independently (something like /data/OldChive/.snapshots/XX/snapshot for each one).
SGT_Oldy
Nov 19, 2019Aspirant
Hey StephenB
First things first, you said the file system is become corrupted, any idea why or how to prevent it happening again?
Onto the current situation...
Thanks... not fixed yet but better understanding. You told me to use "btrfs subvolume list /data" to see what it was I could not before and to know what to delete.
I used that and found:
ID 287 gen 245200 top level 285 path OldChive/.snapshots (and / or)
ID 9439 gen 242748 top level 287 path OldChive/.snapshots/99/snapshot
Being hidden I could not see it before, so YEAH! now I can see what I want to delete. So I did cd data/OldChive/.snapshots
and entered this line
root@XXNASXX:/data/OldChive/.snapshots# rm -rf 99/
but from there I got about a bajillion lines listing each dir and file and
rm: cannot remove '99/snapshot/(each dir and each file of the dir)': Read-only file system
I tried to use the Admin page to try to change the permissions, as well as windows file expoloer but that did nothing helpful. I then used Google to find the Linux command to change the dir and files from R to RW. However, chmod is not part of the OS, and I could not find any other commands.
If this was a Cisco, Dell, or even a dammed Brocade switch or router I could command line that thing with no problem, but I am not as good with Linux as I wish I was.
I looked back at my purchase info, I bought a diskless system off of Newegg on EXACTLY 5/31/2016. I will try during the day instead of evening to use the chat support, however do you know if they will be upset that I have accessed via SSH already? I have this NAS at home btw, maybe I am strange, but I like tech stuff lol.
Sandshark
Nov 19, 2019Sensei
If the NAS has made the file system read-only, then it has detected something it thinks could go catestrophically wrong if you write more to it. There is really no way around that that I have found than backing up the data while you can, doing a factory default, and re-building.
