NASPro2user
Mar 19, 2012Aspirant
cp: preserving permissions for XXXX operation not supported
I have a ReadyNASPro2, Firmware RAIDiator 4.2.18. I am backing up from the ReadyNAS to an external USB 3.0 Seagate 2TB drive. The backup does seem to work, as it appears all the folders and files ar...
ReadySECURE
Mar 19, 2012Apprentice
Are there preexisting files on the drive prior to using it for backups from the ReadyNAS or is this a freshly formatted USB drive?
Are you using this for portable access or just for backups from the ReadyNAS?
Are you currently accessing files through SSH?
