NASPro2user
Mar 19, 2012Aspirant
cp: preserving permissions for XXXX operation not supported
I have a ReadyNASPro2, Firmware RAIDiator 4.2.18. I am backing up from the ReadyNAS to an external USB 3.0 Seagate 2TB drive. The backup does seem to work, as it appears all the folders and files ar...
NASPro2user
This was new Seagate external drive. Connected it to the NAS right out of the box. The only files on it are some Seagate files. Did not format and has not been used for anything but NAS.
Not using it for portable access. It stays connected to the ReadyNAS.
Backing up after configuring backup jobs using Frontview.
I am not connecting through SSH. Browse to the drive and folders with Window Explorer.
Thank you.
Thank you.
