NASPro2user
Mar 19, 2012Aspirant
cp: preserving permissions for XXXX operation not supported
I have a ReadyNASPro2, Firmware RAIDiator 4.2.18. I am backing up from the ReadyNAS to an external USB 3.0 Seagate 2TB drive. The backup does seem to work, as it appears all the folders and files ar...
ReadySECURE
Mar 19, 2012Apprentice
If you are only using this for the ReadyNAS, I would suggest formatting with the NAS. To perform this go to Volumes > USB. In the drop down menu you will see some formatting options. If you do not plan to use this as portable access for the data, and only for the ReadyNAS, I would honestly suggest using the EXT formatting. You may use FAT as well to have great compatibility if you decide to connect it to a PC to access the files.
If you have any critical, non-replaceable, data on the USB drive, I would recommend backing it up off of the drive, and then formatting the drive with the ReadyNAS in the fore-mentioned formats.
