NASPro2user
Mar 19, 2012Aspirant
cp: preserving permissions for XXXX operation not supported
I have a ReadyNASPro2, Firmware RAIDiator 4.2.18. I am backing up from the ReadyNAS to an external USB 3.0 Seagate 2TB drive. The backup does seem to work, as it appears all the folders and files ar...
NASPro2user
I have some large files bigger than FAT32 allows.
If I format in EXT3, will I be able to browse to the folder, files, copy, etc, using Windows? What if I want to copy back over one or more backed up files on the USB drive to the ReadyNAS, or even to my desktop. With EXT3 being a Linux format, am I going to be able to do this?
