NASPro2user
Mar 19, 2012Aspirant
cp: preserving permissions for XXXX operation not supported
I have a ReadyNASPro2, Firmware RAIDiator 4.2.18. I am backing up from the ReadyNAS to an external USB 3.0 Seagate 2TB drive. The backup does seem to work, as it appears all the folders and files ar...
mdgm-ntgr
Jul 10, 2012NETGEAR Employee Retired
The NTFS filesystem can't store the Linux file permissions. So the files are copied but the permissions aren't retained.
