NASPro2user
Mar 19, 2012Aspirant
cp: preserving permissions for XXXX operation not supported
I have a ReadyNASPro2, Firmware RAIDiator 4.2.18. I am backing up from the ReadyNAS to an external USB 3.0 Seagate 2TB drive. The backup does seem to work, as it appears all the folders and files ar...
HERBIEO
Jul 16, 2012Aspirant
NASPro2user wrote: I have some large files bigger than FAT32 allows.
If I format in EXT3, will I be able to browse to the folder, files, copy, etc, using Windows? What if I want to copy back over one or more backed up files on the USB drive to the ReadyNAS, or even to my desktop. With EXT3 being a Linux format, am I going to be able to do this?
You could install Ext2 Installable File System for Windows > http://www.fs-driver.org/index.html
