williams_nest
Aug 10, 2014Aspirant
CPU and Fan upgrades
Hi there, I'm new here - just wanted to confirm that my current upgrades all worked as planned. My "old" ReadyNAS PRO 6 bought in 2012 - at first equipped with 6 X 2TByte disks - in 2013 upgrade...
williams_nest
Mar 31, 2015Aspirant
I would not upgrade the CPU to the Quad core without better fans - but thats just me - and besides - not that impossible to get by
http://www.ebay.com/itm/Noctua-NF-F12-PWM-120x120x25mm-4-Pin-1500-1200rpm-Max-12cm-case-fan-/181682627043
http://www.ebay.com/itm/Noctua-NF-R8-PWM-Raised-Blade-Low-Noise-SSO-Bearing-80x80x25mm-Fan-/251248926930
And not that expensive :-)
