ikonuk
May 15, 2017Guide
CPU Temperature on a RN102 running OS 6.6.1
The temperature gage shows 153 deg F (image is attached). Is this normal. It is running OS 6.6.1, no apps installed, disk spin down is ON. Any advice would be appreciated. I. Konuk PS...
- Retired_MemberMay 16, 2017
yup, sometimes cpu gets pretty hot in rn10x depending on situation. i would set the fan to "cool".
Retired_Member
May 16, 2017yup, sometimes cpu gets pretty hot in rn10x depending on situation. i would set the fan to "cool".
- ikonukMay 17, 2017Guide
Thanks very much. It dropped to 127 deg F after I switched to "cool" mode.
