jasont1
Mar 19, 2012Aspirant
Crashplan Headless
I have been all over these forums, google, etc trying to figure this out. I have a ReadyNas Pro 6. Crashplan Pro has been installed via the instructions provided in this forum. That part went fine ...
Mar 19, 2012Guru - Experienced User
You need to make an edit in crashplan/conf/ui.properties
Line 3 needs to be changed from
Also - when you select your backup folders, you need to select the shares shown under "C", and ignore the top level list (which are actually links).
#servicePort=4243to
servicePort=4200changing the port number AND removing the initial #
