jasont1
Mar 19, 2012Aspirant
Crashplan Headless
I have been all over these forums, google, etc trying to figure this out. I have a ReadyNas Pro 6. Crashplan Pro has been installed via the instructions provided in this forum. That part went fine ...
jasont1
Mar 20, 2012Aspirant
Found a weird quirk. Luckily, I had made a backup copy of ui.properties before making any changes. I was using notepad to edit the file initially. I then went back to the backup file I created and opened it with wordpad, made the changes, and resaved as ui.properties.
Now, when trying to connect the desktop engine, I am getting a message that says, "unable to connect to the backup engine, retry?" - this is positive movement. Now, it is either the firewall blocking it, or an issue with the readynas install of Crashplan.
As my linux is not very good. Is there a quick check I can do to make sure the engine is running correctly on the ReadyNAS?
