jasont1
Mar 19, 2012Aspirant
Crashplan Headless
I have been all over these forums, google, etc trying to figure this out. I have a ReadyNas Pro 6. Crashplan Pro has been installed via the instructions provided in this forum. That part went fine ...
jasont1
Mar 20, 2012Aspirant
I am still connected, I typed in ps -x and in the printout, "/usr/bin/java -Dfile.encoding=UTF-8 -Dapp=CrashPlanSerive...." is listed.
I still have an active PuTTY session with the port forwarding.
Still unable to connect.
Also, per http://support.crashplan.com/doku.php/recipe/stop_and_start_engine, specifically the following -
I am able to change to /usr/local/crashplan/bin but when I try to stop or start the service, I get "CrashPlanEngine: command not found" I tried this with "CrashPlanService also.
How It Works - Linux
The start / stop script is stored in the crashplan/bin directory (default for a root install is: /usr/local/crashplan/bin).
Usage:
CrashPlanEngine stop|start
