jasont1
Mar 19, 2012Aspirant
Crashplan Headless
I have been all over these forums, google, etc trying to figure this out. I have a ReadyNas Pro 6. Crashplan Pro has been installed via the instructions provided in this forum. That part went fine ...
Mar 20, 2012Guru - Experienced User
if ps -x shows it, then it is running. So there is no need to start or stop it. You could re-boot the NAS of course (though you would have to re-open the putty connection).
I guess it is possible that your windows firewall or security software is interfering with the port forwarding??? Though it seems strange, since they are not interfering with the command line window. Did you try disabling them?
