jasont1
Mar 19, 2012Aspirant
Crashplan Headless
I have been all over these forums, google, etc trying to figure this out. I have a ReadyNas Pro 6. Crashplan Pro has been installed via the instructions provided in this forum. That part went fine ...
jasont1
Mar 22, 2012Aspirant
Stephen, you're a freaking genius!
The alternate directions were the key to tip me off. I checked the my.service.xml file and found that the ServiceHost line was already set to the nas IP (instead of 127.0.0.1 or localhost). Due to this, when I was setting up the SSH tunnel using localhost:4243, crashplan didn't know how to handle that.
After changing the SSH tunnel to <NAS IP>:4243, I was able to connect without issue.
Must have done something in the initial setup to change that...not sure...either way, that did it!
Thank you for all the help, it was greatly appreciated!
Jason
Jason
