jasont1
Mar 19, 2012Aspirant
Crashplan Headless
I have been all over these forums, google, etc trying to figure this out. I have a ReadyNas Pro 6. Crashplan Pro has been installed via the instructions provided in this forum. That part went fine ...
jasont1
Mar 26, 2012Aspirant
Uninstalled CrashPlan from the ReadyNAS over the weekend and installed CrashPlanPRO. After this, the connection worked without an issue. I was even able to follow the tunnel directions using localhost instead of the ip of NAS.
Thanks again for all the help.
To anyone that happens to come into a similar issue, please make sure you are using the appropriate install version (Regular vs PRO vs PROe). Will save a LOT of headaches.
