dereky42
Dec 13, 2015Aspirant
Crashplan not backing up. JAVA error looking up function 'inotify_init1'
Hello, I've been running Crashplan on my ReadyNAS Ultra 4 for awhile now, but since 11/26/2015, it hasn't been backing up my files. ReadyNAS Ultra 4 RAIDiator 4.2.27 Crashplan 4.5.0 (versi...
- Dec 13, 2015
You may wish to have a read through this thread: https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/m-p/1013370#M11396
To run the Java version required you will need to install either the Dropbox add-on or the (g)libc6 2.13 add-on
mdgm-ntgr
Dec 13, 2015NETGEAR Employee Retired
dereky42
Dec 14, 2015Aspirant
Hi mdgm,
Thanks for the quick response. I read through the thread. Turns out my problem is the same as the other problem. (Crashplan version 4.5.x+ requires glibc 2.9+)
I upgraded to RAIDiator 4.2.28, then installed the free libc6 2.13 add-on provided by WhoCares.
Crashplan looks like it's doing it's thing now. :)
Thanks!
Derek
