Feb 23, 2012Guru - Experienced User
CrashPlan performance
Just got up and running with CrashPlan on my PRO 6, and was wondering what upload speeds people are seeing. So far I am generally seeing between 5 and 12 mbps (much slower than my internet uplink)....
fbmachines
Feb 23, 2012Guide
On my Pro-6 I max out my upload speed but it's only 9 mbps. You may want to check with CrashPlan and see if there are any other settings you can change.
BTW, what is your upload speed rated at?
I like to test mine at...
http://www.speedtest.net/
Post your results if you get a chance.
