Feb 23, 2012Guru - Experienced User
CrashPlan performance
Just got up and running with CrashPlan on my PRO 6, and was wondering what upload speeds people are seeing. So far I am generally seeing between 5 and 12 mbps (much slower than my internet uplink)....
stgeorge
Dec 12, 2013Guide
StephenB--> I'm considering a headless CP setup on my Pro6, so I have a few questions: 1) Are you still using it and still pleased with its performance overall? 2) Does CP allow you to send them one of your HDs to make the initial backup startup go a bit less painfully? (I only have about 5mbps upload over my home's ISP), 4) has there been any community add-on developed for CP interfacing? 5) what is java needed for in the step-by-step setup routine?
Thanks!
Thanks!
