sdouek
Jul 07, 2015Guide
CrashPlan updated to 4.3 and now my GUI will not connect.
OK CrashPlan updated to 4.3.0 and now my Windows 7 GUI will not connect. The fix: 1)Make sure Windows 7 GUI is 4.3 and make sure it is not running when you are doing the steps below: 2) Copy yo...
sdouek
Jul 07, 2015Guide
I assume that people are installing Crashplan without the need to tunnel via ssh. You can do away with the tunneling by editing my.service.xml on the NAS to your NAS ip address and just put in your address in the ui.properties file located on your PC.
But either way works.
StephenB do you see any cons to the above fix ?
