sdouek
Jul 07, 2015Guide
CrashPlan updated to 4.3 and now my GUI will not connect.
OK CrashPlan updated to 4.3.0 and now my Windows 7 GUI will not connect. The fix: 1)Make sure Windows 7 GUI is 4.3 and make sure it is not running when you are doing the steps below: 2) Copy yo...
Jul 07, 2015Guru - Experienced User
I've just left it at tunneling. The GUI is fine as far as it goes, but I like to look at the tail of various logs also, so I'm logging in with SSH anyway.
sdouek wrote: I assume that people are installing Crashplan without the need to tunnel via ssh.
No cons, and the files were just where you said they were. It just wasn't enough in my case because the upgrade also disrupted the tunnel. Your post actually made solving my problem much faster, since it pointed me to c:\ProgramData\Crashplan.
sdouek wrote: StephenB do you see any cons to the above fix ?
As a practical matter, Windows explorer can misbehave on files that start with . If that happens to you, you can use the windows command shell to rename files.
