sdouek
Jul 07, 2015Guide
CrashPlan updated to 4.3 and now my GUI will not connect.
OK CrashPlan updated to 4.3.0 and now my Windows 7 GUI will not connect. The fix: 1)Make sure Windows 7 GUI is 4.3 and make sure it is not running when you are doing the steps below: 2) Copy yo...
sdouek
Jul 11, 2015Guide
I checked my C:\ProgramData\CrashPlan\ui_username.properties the port was set to 4243 and in c:\Program Files (x86)\CrashPlan\conf\ui.properties the port was set 4200 and I wsa able to connect via ssh tunneling.
my.service.xml on the NAS was set to my NAS ip address, I don't know if that is what you have or is it set to 127.0.0.1 or sometimes when you change the settings in CrashPlan GUI on the PC you have to end the process tree in task manager, it may make a difference ?
C:\ProgramData\CrashPlan\ui_username.properties, It had the following:
#Sat Jul 11 15:25:21 EDT 2015
expandedDestinations=1\:42
servicePort=4243
window=0,0,1920,1024
#Fri Dec 09 09:50:22 CST 2005
serviceHost=XXX.XXX.XXX.XXX
servicePort=4200
#pollerPeriod=1000 # 1 second
#connectRetryDelay=10000 # 10 seconds
#connectRetryAttempts=3
#showWelcome=true
#font.small=
#font.default=
#font.title=
#font.message.header=
#font.message.body=
#font.tab=
servicePort=4243
servicePort=4200
#showWelcome=true
#font.small=
#font.default=
#font.title=
#font.message.body=
#font.tab=
