sdouek
Jul 07, 2015Guide
CrashPlan updated to 4.3 and now my GUI will not connect.
OK CrashPlan updated to 4.3.0 and now my Windows 7 GUI will not connect. The fix: 1)Make sure Windows 7 GUI is 4.3 and make sure it is not running when you are doing the steps below: 2) Copy yo...
Jul 11, 2015Guru - Experienced User
I didn't end it with taskmanager; I right-clicked on the icon in the notification tray, and selected exit.
c:\Program Files (x86)\CrashPlan\conf\ui.properties has servicePort=4200 and serviceHost commented out.
servicehost on the NAS (my.service.xml) is 127.0.0.1; serviceport is 4243
C:\ProgramData\CrashPlan\ui_username.properties now has servicePort set to 4200
