sdouek
Jul 07, 2015Guide
CrashPlan updated to 4.3 and now my GUI will not connect.
OK CrashPlan updated to 4.3.0 and now my Windows 7 GUI will not connect. The fix: 1)Make sure Windows 7 GUI is 4.3 and make sure it is not running when you are doing the steps below: 2) Copy yo...
Jul 11, 2015Guru - Experienced User
I believe the code42 guide does set up a tunnel (certainly it did at one point).
tony359 wrote: Shall I add this to the guide? I don't see the advantage of using a tunnel...
I'm running ssh anyway (since I tail history.log.0 and backup_files.log.0 first, and often that's all I do). So I use the tunnel method.
But I think the main reason sdouek posted is because he got a different result than I did with 4.3.0. My tunnel didn't work until I changed C:\ProgramData\CrashPlan\ui_username.properties. Sdouek's tunnel worked w/o making that change.
