sdouek
Jul 07, 2015Guide
CrashPlan updated to 4.3 and now my GUI will not connect.
OK CrashPlan updated to 4.3.0 and now my Windows 7 GUI will not connect. The fix: 1)Make sure Windows 7 GUI is 4.3 and make sure it is not running when you are doing the steps below: 2) Copy yo...
tony359
Jul 12, 2015Apprentice
Why would you want to skin a cat? ;)
I'll add the note on the bottom notes. Stephen, yes, Code42 mentions the tunnel but for the average user using SFTP is so much easier. That way you don't need to learn how to use Linux!
