sdouek
Jul 07, 2015Guide
CrashPlan updated to 4.3 and now my GUI will not connect.
OK CrashPlan updated to 4.3.0 and now my Windows 7 GUI will not connect. The fix: 1)Make sure Windows 7 GUI is 4.3 and make sure it is not running when you are doing the steps below: 2) Copy yo...
sdouek
Jul 14, 2015Guide
If the EJRE addon is already installed on your system do not uninstall it, it is still needed globally and as per MinimServer.
Uninstalling the Java runtime
To remove the EJRE installation from your ReadyNAS, remove the EJRE Installer add-on. This removes the installed EJRE files, but doesn't remove the original EJRE .tar.gz file from the backup share.
