sdouek
Jul 07, 2015Guide
CrashPlan updated to 4.3 and now my GUI will not connect.
OK CrashPlan updated to 4.3.0 and now my Windows 7 GUI will not connect. The fix: 1)Make sure Windows 7 GUI is 4.3 and make sure it is not running when you are doing the steps below: 2) Copy yo...
sdouek
Jul 17, 2015Guide
Uninstalling EJRE will uninstall your global Java and may break your JAVA libraries.
What I meant was if you uninstall it and don't replace it with another global Java it may break your Java libraries.
Since CrashPlan 4.3 installs it's own local to the application JAVA to use and does not install Java globally like the EJRE install, CrashPlan will not replace the global Java you just removed with the EJRE.
