sdouek
Jul 07, 2015Guide
CrashPlan updated to 4.3 and now my GUI will not connect.
OK CrashPlan updated to 4.3.0 and now my Windows 7 GUI will not connect. The fix: 1)Make sure Windows 7 GUI is 4.3 and make sure it is not running when you are doing the steps below: 2) Copy yo...
tony359
Jul 17, 2015Apprentice
Ok, thanks.
So the question is: does a RN come with Java installed? If I uninstalled the global Java and re-installed CP, it should work. What else uses Java on the RN?
