beatwiho
Aug 09, 2015Aspirant
cron job with shell script
Hi, the pictures of my network cameras are uploaded via ftp to the NAS. I need a cron job that deletes files older than 7 days automatically. i enabled root SSH access to the NAS already. ...
Danthem
Aug 15, 2015NETGEAR Employee Retired
Hi beatwiho,
First of all please note that incorrect SSH usage may result in rejected support (until you factory default).. The script below is not official and is used at your own risk.
Anyways, I don't know what NAS you have as you didn't write it but assuming that you have a OS6 unit and running the default volume name, the script could look like this:
find /data/SHARE/SUBFOLDER/* -mtime +7 -exec rm {} \;
You will need to change "SHARE/SUBFOLDER" to whatever the path is to your folder.. For instance if it's in cameras/videos the path should be /data/cameras/videos/*. Note that "data" is the default name of OS6 volume.
Note that this is for OS6, OS4 would be different.
You can then create a cronjob to run, let's say at 01:00 every day, week, month and year, edit your crontab by running
crontab -e
and then, using whatever text editor pops up (vi most likely) modify your crontab file to have the following entry at the bottom:
0 1 * * * find /data/SHARE/SUBFOLDER/* -mtime +7 -exec rm {} \;At 0 minutes of the hour, 1st hour of the day, every day of the month, every month of the year, every weekday (mon-sun) (so; 01:00 every day), run the script that finds every file older than 7 days in folder X and then RM it. Note that this script does not delete subfolders, only files.
I'm writing this from memory and with no possibility to test it at the moment, I'd recommend setting it up on a test folder first to make sure it works as intended. There may be other ways to do this, but this is a fairly simple way.
and once again; the above and any SSH usage is completely at your own risk.
- beatwihoAug 16, 2015Aspirant
Hi Danthem,
Thanks for the detailed description.
running like a charm.
