dcg13
Aug 27, 2018Aspirant
Cron, rsync, broken pipe, and SSH disconnecting
Hi- I'm trying to move 3TB of files from a Drobo to a ReadyNAS 214.
The Drobo is directly connected to the ReadyNAS via USB.
My approach is to SSH into the ReadyNAS then use rsync.
However, the...
mdgm-ntgr
Aug 27, 2018NETGEAR Employee Retired
You can try using things such as screen, nohup or dtach rather than running on a schedule if you prefer.
dcg13
Aug 29, 2018Aspirant
Thanks for the suggestions, I will try to try those.
I wrote 'try to try' because of how frequently the SSH session closes-- I can barely "get in" before it exits. While nohup will help me to continue processes after logout, how can I resolve the SSH disconnects? I'm running
ssh -v [email protected]
- mdgm-ntgrAug 29, 2018NETGEAR Employee Retired
Not sure why the SSH connection would be disconnecting so quickly. My SSH connections I've always found to be reliable.
- dcg13Aug 31, 2018Aspirant
Yes, the SSH closes after anywhere from 30sec - 15min. I also just switched, in context of troubleshooting, to a different Macbook, with the same result. Frequently, after the connection closes, it cannot be reopened without rebooting the ReadyNAS.
It's quite frustrating, as I've been trying since early July to move data off of the Drobo onto the ReadyNAS, and I feel I'm making very little progress.
- StephenBSep 01, 2018Guru - Experienced User
How full is the OS partition on the NAS?
Is the SSH connection stable if you simply leave the SSH connection open, (not attempting to transfer data from the drobo)?
