SLK-Purdue
Jan 29, 2017Luminary
Daily (almost) UPS Communication error
I see a periodic (almost every day) UPS Communication Error at 1900h. This is too regular to not be a software error. I am running 6.6.1. This is nothing else in the logs at this time. I believe ...
FramerV
Jan 31, 2017NETGEAR Employee Retired
Hi SLK-Purdue,
Not sure if this is related to the AV issue that is being investigated. Can you try to disable your Anti-Virus and see if it will make any difference.
SLK-Purdue
Feb 12, 2017Luminary
Problem continues with AV disabled.
New data - this is clearly clock based. When I adjust the time, the problem moves accordingly. I have confirm I can see nothing in the cron logs. Any clues?
- FramerVFeb 13, 2017NETGEAR Employee Retired
Hi SLK-Purdue,
May I ask for the system logs? I will try to inquire about your case.
How do I send all logs to ReadyNAS Community moderators?
- nsneFeb 15, 2017Virtuoso
I'm seeing this issue too. Didn't realize a thread of sorts had already been created when I posted mine: https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/Regular-UPS-disconnects-reconnects/m-p/1229958
- FramerVFeb 18, 2017NETGEAR Employee Retired
Hi SLK-Purdue,
If in case you would want to try, we have the BETA firmware released already.
ReadyNASOS 6.7.0-T158 (Beta 1)
- SLK-PurdueFeb 19, 2017Luminary
Thanks for the offer. I don't have a spare unit available at the moment to try a Beta. Primary units are being used for some important work and need to not take beta risk with those units. Did you find a problem that explains this behavior?
Thanks,
Scott
- FramerVFeb 19, 2017NETGEAR Employee Retired
Hi SLK-Purdue,
I am not really within the loop regarding the bugs that they find. Might be best to follow StephenB's advise to PM Skywalker about it
