Askii
Nov 21, 2018Tutor
Dashboard nicht erreichbar
Hallo,
ich kann nicht mehr auf das Dashbaord zugreifen, es wird immer angezeigt das keine sichere Verbindung zu der Website besteht, leider konnte ich im Internet auch nichts zu dem Thema finden ob...
Nov 21, 2018Guru - Experienced User
What browser(s) have you tried? Can you post of screen shot of the security warning? Normally you can click through them, and still access the NAS.
What firmware is running on the NAS?
Askii
Nov 22, 2018Tutor
I tried Chrome and IE10, both of them showed up the Dashboard when i logged in a few month ago. I had to click throuh the security Warning to log in. But now there is nothing to click.
- StephenBNov 22, 2018Guru - Experienced User
What firmware are you running on the NAS?
Did you try rebooting it?
- AskiiNov 22, 2018Tutor
It is Firmware 5.3.13 and i tried to Reboot it.
I can use the NAS, its working but i can not reach the Dashboard because of a missing protocol or something else.
Thanks for your helpManuel
Perhaps try clearing the browser cache and rebooting the PC next?
Then try a direct connect procedure (connecting the NAS directly to the PC via ethernet, and temporarily assign a static IP address to the PC.
If the NAS uses the default DHCP, then you can set the PC to use
- IP address: 192.168.168.100
- Subnet Mask: 255.255.255.0
- Gateway: 192.168.168.1
Then browse to http://192.168.168.168 and see if that works.
