azerva
Jul 24, 2015Tutor
Data Volume Lost after Disk Replace #25483643
Hello ReadyNAS Community,
after a disk failure (disk 3), I replaced this disk. A volume resynchronization was started automatically. However, this resynchronisation failed with no obvious error...
JohnRo
Jul 24, 2015NETGEAR Employee Retired
Hi azerva,
I looked at some information on the logs you have sent and on my understanding, it appears that Drive 4 may have also failed. To confirm this, please download disk diagnostic tools from Western Digital (WD lifeguard) or Seagate's(Seatools) webiste and check your drives. My hopes are still high that your data will be recovered.
I'll look forward to your response.
Thanks,
azerva
Jul 25, 2015Tutor
JohnRo wrote:Hi azerva,
Thanks,
Hi JohnRo,
I connected disk 4 to my PC and I can see it using SeaTools. Which Check / Repair should I try to do?
Thanks in advance.
Alex
