azerva
Jul 24, 2015Tutor
Data Volume Lost after Disk Replace #25483643
Hello ReadyNAS Community,
after a disk failure (disk 3), I replaced this disk. A volume resynchronization was started automatically. However, this resynchronisation failed with no obvious error...
azerva
Jul 29, 2015Tutor
Hi guys,
update on the whole situation. Netgear Support recommended cloning the disk with ddrescue. I did this, the process finished with 4 errors. Below is the log file.
# Command line: ddrescue -fv /dev/sdb /dev/sda ddrescue.log # current_pos current_status 0x14419EC7C00 + # pos size status 0x00000000 0x139A33C4000 + 0x139A33C4000 0x00001000 - 0x139A33C5000 0x00004000 + 0x139A33C9000 0x00001000 - 0x139A33CA000 0xA76AF6000 + 0x14419EC0000 0x00001000 - 0x14419EC1000 0x00005000 + 0x14419EC6000 0x00002000 - 0x14419EC8000 0x8DA724E000 +
If I am reading this correctly, there are 4 relatively small areas (designated by the - at the end which are bad). I tried to start ReadyNAS with disks 1, 2 and the cloned disk 4, however this didn't work.
Are there any additional steps I need to consider? Should I consider re-running ddrescue using the -r option for more retries? Or is there a command to try to re-detect the RAID volume?
Thanks for any hints.
Alex
vandermerwe
Jul 29, 2015Master
Are support not following up on this case?
Did they offer you data recovery services?
