Hombibi
Aug 01, 2015Guide
Data Volume lost after disk replacement on Readynas Pro 6
Hi, I just ran into a serious problem, and I hope someone can help me. Currently my Readynas Pro 6 does not see any volume on the 6 disk X-Raid Array anymore. I walked past my NAS a couple of...
- Aug 22, 2015
Yes, required for other than windows filesystems.
Obviously much cheaper than any professional recovery service.
Hombibi
Aug 11, 2015Guide
Disk 5 and 6 imaged successfully, according to r-Linux.
R-linux can scan the images, I see lots of files but they are all numbered. Hell of a task to open each one and rename.....
So next is trying to recover the array: Downloaded and installed reclaime free raid recovery on a Windows 8.1 laptop and started the raid 5 analysis. Reclaime seems the be very good in finding back the original raid configuration, which can than be used by r-studio to recover the files with original names and file structure.
After I started the raid 5 scan, reclaime quickly found disk two to be empty. This means that the sync process had failed. If the other images are ok than I think this should be enough. Otherwise I might still have to try to recover the original disk2.
The analysis can take a few days, more news if and when.
