ScotPjotr
Feb 07, 2019Follower
Data wiped
Good afternoon,
I have been using my ReadyNAS for several years with great joy. During this time the whole family has been saving pictures, media files and backups to the device in the understandin...
- Feb 07, 2019
Hi ScotPjotr
Welcome to the Community!
Sorry to hear you are having this issue,It seems that from what you have told it's not only one drive that has failed since the volume got inactive, possibly a multiple disk failure happened rendering the RAID volume to disappear or get inactive. There are still ways to try and recover data, one option is to contact NETGEAR Support through my.netgear.com and purchase a Data recovery contract to have it checked and recover the data or use a third party software like r-linux or ReCLAIMe.
While RAID provides protection to your data in the event of a disk failure that should not be confused as a good backup solution, Important data should always be backed up somewhere (Ext drive, another NAS) you should always keep multiple copies of your important data to say. As they say, using a NAS for storage is part of a Backup but it shouldn't be the only location where your important data is stored.
Hope this helps!
Regards
Marc_V
Feb 07, 2019NETGEAR Employee Retired
Hi ScotPjotr
Hope this helps!
Regards
