q3d
Mar 26, 2024Aspirant
Dead RN316
I have a RN316 (6 bay) that stopped working (not powering up) - it's EOL. I'd like to replace the PSU to determine if that is the reason or if it's the MB. The exiting PSU is a DPS-200PB-186A (...
- Mar 29, 2024
Yes, the modifications to the 20-pin connector for the legacy NAS are the same as for the native OS6 ones. You should be able to confirm that based on the colors of the wires in your old one. Most of the later ones do need the 4-pin CPU power connector, so that supply won't work with those since it lacks one. But since the 316 doesn't need it, it should work fine.
Sandshark
Mar 27, 2024Sensei
The RN316 (and all ReadyNAS with a 20-pin power connector) pin-out is non-standard. The -5 and -12V pins have been replaced with +12V. For a simple driveless test to see if it'll power up, you can just pull or cut the -5V and -12V pins from the power supply cable. If that works, then splice in 12V from one of the unused connectors, like the 4-pin Molex (old style hard drive) connectors.
q3d
Mar 28, 2024Aspirant
Sandshark wrote:The RN316 (and all ReadyNAS with a 20-pin power connector) pin-out is non-standard. The -5 and -12V pins have been replaced with +12V. For a simple driveless test to see if it'll power up, you can just pull or cut the -5V and -12V pins from the power supply cable. If that works, then splice in 12V from one of the unused connectors, like the 4-pin Molex (old style hard drive) connectors.
So on a 20 pin PSU cable, these 2 pins (highlighted below in blue), once removed should at least power up the NAS? (for anyone else reading this thread):
So, I remove those 2 pins from the new PSU and the NAS powered up fine (so the old PSU is gone).
Next, I just replace those with pins with 2x +12V wires?
The usual ATX PSU 4pin connectors have 2x +12V wires - I can use these 2 (yellow) in the (above) 20 PIN cable instead?
Or even using 2 of the PSU 4-pin (HDD) ones (yellow)?
Are these 2 +12 V pins used to power the HDD's in the RAID array?
