jumanji68
Oct 22, 2021Follower
Debug Code 50178 for NV+ v1
On a recent reboot of my NV+, the chassis stopped at Booting...Found Bad Disk. When I boot it up in Tech Support Mode, I am able to use RAIDar to return Debug Code 50178. Can anyone provide a list of...
Oct 23, 2021Guru - Experienced User
FYI, this is not an error code. It's a code that Netgear can use to access your NAS remotely.
BTW, if you use telnet the username is root, and the password is infr8ntdebug.
In addition to mdgm's commands, you can also power down the NAS, and remove the disks (labeling them by slot). Then you can connect them to a PC (using either SATA or a USB adapter/dock) and test them there. You can use vendor tools (Seatool's Seatools, or WD's Lifeguard or Digital Dashboard).
