MikeB666
Jul 28, 2014Tutor
Defrag Running for Days! #23600598
I have a ReadyNAS 104 (OS six.one.eight) with 4 x 4TB drives in a single X-RAID RAID 5 volume so you get about 10.9TB usable. The system has 5.02TB of data on it. The system started a defrag last T...
ReadySECURE
Jul 28, 2014Apprentice
How do you use your device?
My defrag of 18TB on 716X took about 24 hours to run last time I looked... but that's a 716X on 6X4TB RAID5. If you have a lot of files on your device and there is a lot of fragmentation on those files, it could take a long time to run (depending on how the device is used during defrag). You can download your logs and look under the process log to see if btrfs defrag is running.
