MikeB666
Jul 28, 2014Tutor
Defrag Running for Days! #23600598
I have a ReadyNAS 104 (OS six.one.eight) with 4 x 4TB drives in a single X-RAID RAID 5 volume so you get about 10.9TB usable. The system has 5.02TB of data on it. The system started a defrag last T...
xeltros
Jul 28, 2014Apprentice
I do use snapshots yes. Daily for some shares, weekly for others. That said I had no substantial data moves for a while now (except Time Machine and maybe 10Gb of files this month).
I asked about the %wa as I had the problem back to 6.1.4 I think (not sure) with big files, the NAS was freezing and had to be rebooted electrically to work properly and I was having those really high %wa like if the NAS was waiting for the disks. The next version patched it up though.
This also reminds me that there were BTRFS updates with 6.1.4, I reset my NAS to get them applied and I believe some of the improvements concerned stability. @Mike did you do a factory default after upgrading to 6.1.4 ?
