MikeB666
Jul 28, 2014Tutor
Defrag Running for Days! #23600598
I have a ReadyNAS 104 (OS six.one.eight) with 4 x 4TB drives in a single X-RAID RAID 5 volume so you get about 10.9TB usable.
The system has 5.02TB of data on it. The system started a defrag last Tuesday (6 days ago) and the log entry confirms the start of the defrag. Since then no entries about completion.
Should a defrag really take a week or more ?
Thanks
Thanks
- MikeB666Tutorxeltros - looking at top - the %wa is about 44%'ish, and the processes causing this are the expected : btrfs, btrfs-endio-met, btrfs-trasncti and md127_raid5 (assuming these are the defrag process as the other ReadyNAS not running a defrag is not showing these and clocking almost no cpu/process time)
So just looks like a massively long running slow defrag.
(side points, no snapshots, no AV, no apps of any kind, not much new data being written either) - StephenBGuru - Experienced User
They made some changes in the disk format in 6.1.5 which were intended to increase performance somewhat. If you want the new format settings, you do need to reset. I didn't bother myself, since I wasn't seeing a lot of performance issues with my RN102.MikeB666 wrote: ...Also - are we really expected to do a factory reset after a firmware upgrade which will wipe the disks, seems a little harsh...
Is it believed that this will really make any difference - since the disk were bare when written too first time around and it was done in mostly one massive write session to back up another real file server (massive number of files from small, a few KB, to 60GB in size).
Normally firmware updates don't require this, but there have been a few over the years that did suggest it. For instance, it was needed on the NV+ v1 some years ago in order to get 4K sector alignment of the data volume.
Of course, a factory reset is one way to get rid of your long-running defrag... - MikeB666Tutor
Thanks Stephen - I'm on vacation soon so may just let it run then see where I am :-) - mdgm-ntgrNETGEAR Employee RetiredMy comment about was just saying that when you first setup the NAS and hadn't yet loaded data on, a factory reset on the latest firmware would have been good. Some improvements (not necessary but nice to have) can only be obtained via a factory reset on new firmware, so I always recommend with a new setup, updating to the latest firmware, verifying the update completed successfully, doing a factory reset and only then configuring it and putting data on.
Now that you have loaded a lot of data on one would think all other options should be exhausted first. - MikeB666Tutor
mdgm wrote: My comment about was just saying that when you first setup the NAS and hadn't yet loaded data on, a factory reset on the latest firmware would have been good. Some improvements (not necessary but nice to have) can only be obtained via a factory reset on new firmware, so I always recommend with a new setup, updating to the latest firmware, verifying the update completed successfully, doing a factory reset and only then configuring it and putting data on.
Thanks mdgm, understood.
Well after my vacation I may reset one and then copy back from the other then reset that one too and recopy back to that. - MikeB666TutorSo after Level 3 engineering support have remoted onto my 104 ReadNAS the conclusion is as follows
We got feedback from L3. They said that it is very likely that the defragment will take several days depending on the data. Since the RN104 is a very low performing device it is normal it will take several days to do the defragment. They found out that 1721982 files to go through and it has a lot of small files which is more time consuming because it has to allocate block groups that the data sits on
So after a reboot we are going to let it run for 11 days until month end then see where we are. While I look for something more capable of holding more than 5TB of files and being able to defrag them etc. [might just build another Windows File Server to do the job :-( ]
Mike
