Bent82
Jan 19, 2016Guide
Deleting old home directories
A few years ago I upgraded from an old NV to a 314, OS 6.4.1. I have gotten used to many of the differences, but there is something I still can't figure out how to do. I use AD for users, and every...
- Jan 25, 2016
Hi everyone.
You can't just delete those old home folders because they're btrfs subvolumes.
Though this is not supported by NETGEAR Support, you can remove old home folders with:root@rn314:~# btrfs subvolume list /data | grep home
ID 257 gen 516 top level 5 path home
ID 309 gen 133 top level 257 path home/admin
ID 330 gen 516 top level 257 path home/kohdeeroot@rn314:~# btrfs subvolume delete /data/home/kohdee
Delete subvolume (no-commit): '/data/home/kohdee'
ID 309 gen 133 top level 257 path home/adminBy using SMB to connect to the ReadyNAS as admin, you're exposed to the btrfs subvolumes, but you can't delete; however, this lets you delete files and folders from private home shares to regain your missing space from old home folders.
The subvolumes being there empty hurt nobody. Once you delete the data, the only benefit you get out of deleting the subvolume is for asthetics.
Your subvolume list might be different because you were on a domain. The difference would look like btrfs subvolume delete /data/DOMAIN/USERNAME
Doing this is at your own risk and is not supported by NETGEAR Support.
Bent82
Jan 19, 2016Guide
Hi JennC,
I am not sure I exactly have what you are referring to, but let me see. I can log on to the admin webpage of the ReadyNAS, go to the shares tab, and see and browse the home shares. However, I am unable to delete them, right clicking brings up Browse and Copy, but not delete. Current users show up as a folder with a figure of a person on it, while old, deleted users show up as just a folder, but both behave the same way.
I tried accessing the ReadyNAS though SMB, both as the domain\administrator, and as my own user account (also a domain administrator). Neither allow me to see any home share other than my own in the shares list, and neither can access anything like \\ReadyNAS\home.
StephenB, the users I am trying to delete have already been deleted from AD.
Jan 19, 2016Guru - Experienced User
My guess is that the NAS doesn't immediately delete users when they disappear from AD. If the NAS did that, than any misbehavior in AD itself could result in loss of data. But there should be some way to delete user accounts. Maybe try the "Refresh ADS Accounts" control?
I don't use AD, so I can't offer much on this. There are other people here who use it, perhaps one of them knows how to kill off these stale accounts. You shouldn't be forced to use ssh.
Did you try changing the folder/subfolder owner before you deleted with ssh?
- Bent82Jan 20, 2016Guide
Hi StephenB,
Well, the accounts themselves are gone, if I go look at the accounts page I see the same current list of users I see in AD. That's why I am assuming the folders appear different in the web interface. What I am concerned about is this folders in /home. Most of these folders are empty even, it isn't even a space thing, I mostly want this list of folders up to date for a procedure I am trying to write. In my old NV, I could just browse to /c/ and find the home folders using the domain admin account and delete them, but thyat doesn't work in OS 6. I was suprised that logging in as root using ssh gave me permission errors as well. Changing the owner didn't work either. So I am stumped at the proper way to do this.
mdgm, thanks, PM sent.
- JennCJan 20, 2016NETGEAR Employee Retired
Hello Bent82,
What happens when you map the NAS IP (SMB) and login as admin? This is using the default admin user account of NAS.
I tried this and I don't seem to be able to map.
net use q: \\10.50.38.6 /user:admin password
I get system error 67, the network name cannot be found. Adding the home path to the end of the NAS IP gives me system error 5 Access is denied.
By the way I had completely forgotten about this, but here is a topic I made 2 years ago when I got this ReadyNAS.
https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-314-No-Home-Share-Access/m-p/834936
Looking at this now, I wonder if something is still non-standard from when this happened? It could explain why no suggestions are working.
