KillerBob
Nov 02, 2013Aspirant
Deletion of Aperture and iTunes libraries...
I have my Aperture, iPhoto, and iTunes libraries on my Pro Pioneer. It works fine, and it is relatively fast even when accessing these from my MacBook Pro via WiFi:) However, I work (add and modify pi...
KillerBob
Nov 03, 2013Aspirant
It ended up taking about 12 hours, and it was really just the 60 and the 70GB libraries that took time. There has got to be a better way than deleting these like this??? I have a "PC free" environment, and use AFP for everything. I can try with SMB next time, and I don't think I am ready to try SSH...
How would it work if I simply blew away the entire Share? Would that happen instantly, or would it follow the normal deletion process?
- Aug 04, 2022Retired_Member
- Dec 11, 2018Retired_Member
