SmallworldIT
Jan 28, 2013Aspirant
DeltaCopy PC to NAS 4200 v2 SSH
Hi there, I'm looking for advice for using either DeltaCopy or grsync in order to back up a client computer to our remote NAS (4200 v2), due to the nature of Rsync with its incremental features, this ...
kossboss
Feb 18, 2013Guide
There is no such thing as "rooting the nas" When you install "rootssh" addon it just enabled root ssh - it doesnt void your warranty - however if you mess up your nas whilst in rootssh then it does void your warranty - if you brick the NAS some things to try OS reinstall - always have a backup and Factory Default will definatly fix it (if you didnt cause hardware damage). RootSSH addon requires a reboot and you will be good to go, you will log in to the NAS with your admin password but the username will simply be root.
