steveoelliott
Dec 24, 2015Luminary
device eth0 entered promiscuous mode
Hi all, I noticed something strange in my logs today, it never appears to have happened (certainly since March) before. Dec 17 09:15:57 despair kernel: device eth0 entered promiscuous mode ...
Marto731
Dec 24, 2015Aspirant
Steve,
For clarity, can I get the following.?
NAS model no & Firmware.
The switch it is connected to
Is there a 2nd Eth cable connected to NAS?
I would like to rule out teaming.
Thanks, Marto
steveoelliott
Something on the network must be triggering this! I see the following on the secondary device I have on this LAN:
Dec 17 09:15:57 chaos kernel: device eth0 entered promiscuous mode
Dec 17 09:16:02 chaos kernel: device eth0 left promiscuous mode
Dec 22 14:58:26 chaos kernel: device eth0 entered promiscuous mode
They are connected to Cisco small business switch SD108.
No 2nd interface.
No changes have been made.
Both are ReadyNAS Pro 6 running 4.2.28.
I'm just curious as to why this should occur and also what this avahi daemon thing running is. Probably not related.
- StephenBDec 24, 2015Guru - Experienced User
avahi does Apple discovery (bonjour or rendezvous). https://en.wikipedia.org/wiki/Avahi_(software)
- steveoelliottDec 24, 2015Luminary
Well Bonjour is disabled anyway.
It is a zero-configuration networking tool - and might bundle in some some other services the NAS uses.
Are you using the iTunes server or DLNA?
