Andy1337
Oct 16, 2021Aspirant
Diagnose Readynas Duo
Trying to start my ReadyNas Duo RND2210v2 after it probably was shut down non-gracefully (power outage). It's been stuck for 12 hours and the only LED showing is the Disc Activity LED that blinks eve...
Oct 16, 2021Guru - Experienced User
Let's start by confirming the platform/model.
The original Duo (called v1 here)
- says ReadyNAS Duo on the front panel
- runs 4.1.x firmware
- often has labels that say v2 (and perhaps even v3)
The Duo v2
- says ReadyNAS Duo v2 on the front panel
- runs 5.3.x firmware
Can you let us know which version you have?
- Andy1337Oct 16, 2021Aspirant
It said RND2210v2 on the bottom BUT it says ReadyNas DUO on the front and it likely runs 4.1.6.
- StephenBOct 16, 2021Guru - Experienced User
So it's the original (called v1 here)
If you are looking at the labels, then 4.1.6 would be the firmware it shipped with. Hopefully you updated that periodically. The final firmware was 4.1.16.
Andy1337 wrote:
It's been stuck for 12 hours and the only LED showing is the Disc Activity LED that blinks every 5 seconds. All the other LEDs are not doing anything at all.
Start by powering it down, and removing the disk(s) - labeling them by slot, so you can replace them later on.
The power up the NAS, and see if RAIDar finds it, and reports a "no disks" status. The NAS uses the following LED codes:
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configurationSo the NAS should also give you the "no disks detected" pattern when you do this.
While the disks are removed, it would be good to test them. You need to be able to connect them to a Windows PC to do that (either with SATA or with a USB adapter/dock). Windows won't be able to mount them, but the vendor diags will find them and can test them. Use Seatools for Seagate disks, and either Lifeguard or WD's digital dashboard for Western Digital. Run the full generic (non-destructive) test.
Yes, removing both disks makes RAIDar find the NAS with status "No disks detected". The web interface is not accessible.
Can I remove just one of the disks to see if it's booting?
I have to buy something to connect the HDDs to a PC, if I find that just one of them are working - what are my options?
