tigerten
Oct 18, 2020Luminary
difference between a Readynas Pro 6, Pro 6 Business Edition or Pro 6 Pioneer Edition
I am looking to buy a used 6-bay readynas Pro. How can I tell what I am buying just by the appearance of it? The model numbers are all over the place and I have no clue which is which. Thanks
- Oct 18, 2020
They are all of form RNDP6xxx-y00
The xxx relates to the number and size of the disks (if disks were purchased from Netgear). The "y00" relates to the hardware version: -100 was the first generation, -200 was the second generation.
There's also the Ultra Plus (which had the same hardware). Those part numbers were RNDP6xxU-200.
Oct 18, 2020Guru - Experienced User
tigerten
Thanks.
Here is the exerpt for the Pro 6 Data Sheet:
RNDP6000-200
RNDP6310-200
RNDP6610-200
RNDP6620-200
RNDP6630-200
Your explaination makes perfect sense here.
Are there these?
RNDP6000-100
RNDP6310-100
RNDP6610-100
RNDP6620-100
RNDP6630-100
What are the model number for Pro 6 PE or BE respectly?
Here wha tis said about PE:
Pioneer Edition
– RNDP600E (Diskless)
There is nothing mentioned in the BE Data Sheet.
Again, Thanks
- StephenBOct 18, 2020Guru - Experienced User
tigerten wrote:
Are there these?
RNDP6000-100
RNDP6310-100
RNDP6610-100
RNDP6620-100
RNDP6630-100These are all first generation Pro products (e.g., the Business Edition). The CPU is an E2160 @1.80GHz (the -200 products use a faster E5300 @2.6Ghz)
tigerten wrote:– RNDP600E (Diskless)
Yes, this is the Pro pioneer. The hardware for the Pioneer and the BE is the same. The Pioneer does lacks some software features, including iSCSI, Active Directory and NIC bonding. If you choose to convert them to OS-6, they'd have the same feature set.
The x86 platform to avoid is the NVX, as it can't be converted to OS-6.
- SandsharkOct 18, 2020Sensei
The Pro Pioneer only came diskless and was not updated to a newer processor, so there is only one base part number, RNDP600E-100. There may be differences in some letters that follow, which only affects which countries it was packaged for.
I understand that there are a few very early versions of the ProBE that use an older version of the motherboard that does not have the same processor upgrade capability as the later ones. The remainder can be updated to a CORE2 Duo up to an E7600, providing you first update the BIOS. IMHO, the added speed above the standard processor for the Pro6 (-200) models isn't enough to bother. But if you are upgrading a ProBE or Pro Pioneer, why not go "all the way".
I have been told that the Ultra6Plus also had the slower processor, but the one I have has the faster one. So I don't know if that's just bad info or if an unannounced shift was made along the way.
The ProBE and Pro Pioneer did also ship with the old round-button caddies while the newer ones have the square one, though they could have been swapped by the previous owner.
If buying used on eBay, you are asking the right questions. Especially when the seller is not the actual owner, they often incorrectly label the older ones as a Pro6.
- tigertenOct 19, 2020Luminary
Thank you very much, Sandshark
This is very informative and helpful. However,
"I understand that there are a few very early versions of the ProBE that use an older version of the motherboard that does not have the same processor upgrade capability as the later ones. "
This makes it even more difficult. I think everyone looking to buy one of these older model intends to upgrade either/both software or/and hardware. Knowing its upgradability is key.
"Especially when the seller is not the actual owner, they often incorrectly label the older ones as a Pro6."
This is exactly what I am faced with. He knows nothing about the NAS, and he just randomly copied some text from the internet. And the NAS also is missing a sticker, the upper one (the one with model, serial and mac address etc). All it has is a sticker saying Readynas Pro RNDP6000. As shown in the attached picture.
On the front of it, it says "ReadyNAS Pro, Advanced Network Storage".
I have a feeling this is pro 6, first version, not sure it is a PE or BE. I don't know whether this belongs to those "Very Early" un-upgradable BE model.
