cstrat
Sep 21, 2013Aspirant
Direct link to Boxee, using both network interfaces
hi there! I did try searching the forums but couldn't find what I was after. My setup is as follows: - ADSL Modem/Router with 4 GbE interfaces - ReadyNAS 4 Ultra - Apple TV - PVR - DLink Boxe...
cstrat
Trying to avoid adding new devices!
So are you saying that the ReadyNAS isn't going to be able to route between the interfaces to the internet?
I had thought if I set the right default gateway on the boxee interface, it might work.
Just not certain though...
