David_Smith
Nov 23, 2017Aspirant
Disc Fail Resync Question
Happy Thanksgiving. I have (2) 4 TB discs in my unit. The admin page showed the "disc state" for the disc 2 as having failed. I decided that I should reboot the unit and make sure it wasn't som...
- Nov 24, 2017
David_Smith wrote:
I see 1963 reallocated sectors and after well over 24 hours the resync is only 1.74% complete.
I generally replace disks before they reach 50 reallocated sectors, so I think it is a bad disk.
You can check warranty status and execute the return from WDC's web page. If you are in the US, they offer a service to send you the replacement first, with a return label. It's a reasonable deal, and is the fastest way to get the replacement.
David_Smith
Nov 24, 2017Aspirant
Thanks both of you. I don't know a lot about hard drives but looking at the stats I suspect something is very wrong with the disc even though it is trying to resync. I see 1963 reallocated sectors and after well over 24 hours the resync is only 1.74% complete. I am going to make sure I have a backup and get on the phone with WD and try to get a replacement, I bought commerical drives and I believe it should still be under warranty.
Nov 24, 2017Guru - Experienced User
- David_SmithNov 24, 2017Aspirant
Thanks again, good info, I'm signing up for the advance replacement.
