jthphotography
Sep 02, 2013Aspirant
Disk capacity expansion error. resize2fs
I have an older ReadyNAS, RAIDar recognizes it as a 1000s, but I swear it was called a ReadyNAS NV when I bought it from Infrant (maybe they are the same thing?). Anyway, it has worked flawlessly ove...
mdgm-ntgr
Sep 03, 2013NETGEAR Employee Retired
Yes, a factory default wipes the configuration completely. For RAIDiator 4.x the default admin password is 'netgear1' as you found out.
Odd. You tried restoring the same zip file that you downloaded before the factory reset? I guess you may need to configure your settings again manually then.
Going back to your first post in the thread is your NAS a desktop NAS or a rackmount NAS? The NV is a 4-bay desktop NAS whilst the 1000s is a 4-bay rackmount NAS.
